BACK TO ITALDESIGN - ITALY 09
Messagepar Aquarius (Giovanni) » Dim 10 Mai 2009 à 09:53
Je vais toi dire bientôt, dès que on mesure...seulement un problem:
j'ai du monter 3 pistons tourné de 180° parce que ils sont tous egaux!
Les ranures des valves sont bon pour cammes pas trop sportif, mais si tu monte cammes, pour exemple de 300° d'ouverture, tu dois modifier les ranures sur le ciel du piston.
Aurait été mieux si ils l'avaient fait 3 pistons de droite e 3 de gouche
#6067,fast cams,Hi-co pistons,new injectors,sport exhaust,K&N air filter,sport radiator,Nology,MSD BlasterII coil,Valeo clutch,Toby tabs,lowered springs,front lower arm supports,sport shocks,upper strut bar,polyurethane bushings,Toyo PCF1/Pirelli P600
Aquarius (Giovanni)
Messagepar cineman » Dim 10 Mai 2009 à 14:32
Stainless a écrit:ok mais les pistons ont un taux de compression de combien ?
he is mounting Ed's forged piston, so, according to him, the compression is 9.8:1
cineman
Messagepar johnzgrosjean » Dim 10 Mai 2009 à 16:07
http://www.youtube.com/watch?v=pPyNtufzpFI
ci dessus, deuxième et dernière vidéo de la Trilogie......
johnzgrosjean
Messagepar iudexmaximus » Dim 10 Mai 2009 à 16:41
Aquarius (Giovanni) a écrit:après tous ces cher changements...
International crisis has come to the end! :lol:
Paolo - VIN 000878
iudexmaximus
Messagepar Giascarcio » Lun 11 Mai 2009 à 19:20
These are some picture of the beautiful day that we spend in Torino at the Italdesign.
http://picasaweb.google.com/Giascarcio/ ... fSara7oGQ#
these are some special picture of Giorgetto Giugiaro and his son Fabrizio Giugiaro:
Giorgetto Giugiaro
Fabrizio Giugiaro talk about his memories of the Delorean: he was young but he remembered quite all and a lot of details
of the Delorean. He liked very mutch the car and he have used a lot it when He was a teenager ;) but He remembered it was
a bit slow ;) (the italdesign's delorean is autmatic :P )
In this picture there is Fabrizio Giugiaro trying my delorean with my Turbo engine of the R25, and he say that it's really
really funny, not like his car ;)
this a nice picture of the 3 models of delorean :) 81 82 83
Wait a minute, wait a minute, Doc, are you telling me that you built a time machine... out of a DeLorean?
Owner DeLorean 2.5iV6 TURBO 220cv 1981 VIN SCEDT26T6BD006103 mile 28.500
Giascarcio
Messagepar johnzgrosjean » Lun 11 Mai 2009 à 19:51
grazie mille.. che bella :o :o
johnzgrosjean
Messagepar david » Lun 11 Mai 2009 à 20:33
super les photos !
merci :wink:
c est quoi cette delorean interieur beige ? d ou elle vient ?..........
et celle qui a un drole de moteur ?...........c est quoi ce moulin ?
Messagepar Stainless » Lun 11 Mai 2009 à 20:40
la beige, c'est la voiture de Giugiaro.
le moteur bizarre, le R25turbo de Giacomo
Messagepar cineman » Lun 11 Mai 2009 à 21:01
Stainless a écrit:le moteur bizarre, le R25turbo de Giacomo
There was also a BAE Turbo Delorean and a Delorean with a R25 N/A engine, Z7W.
cineman
Messagepar david » Lun 11 Mai 2009 à 21:01
il a collé un moteur de R25 dans sa Delo ? :shock:
ca developpe combien de chevaux ?
Messagepar Domi » Lun 11 Mai 2009 à 21:13
david a écrit:il a collé un moteur de R25 dans sa Delo ? :shock:
Regarde toutes ces photos sur son album :wink:
Messagepar david » Lun 11 Mai 2009 à 21:22
merci Domi,
mais ça ne répond pas complètement à ma question sur la puissance ?.......
et je suis toujours intrigué ....: ça rentre exactement en lieu et place de l origine, ou faut il aménager les supports moteur et points de fixations au châssis et autres ??
Messagepar Domi » Lun 11 Mai 2009 à 21:29
Il me semble qu'il en avait parlé dans un post, mais je ne me rappelle plus la puissance, désolé :?
Edit: David, la puissance est dans sa signature :wink:
Messagepar cineman » Lun 11 Mai 2009 à 21:30
The power should be around 185hp like the stock R25. We are still working on it, maybe we will change the mapping and boost in the future :)
We changed the lower crankcase of the R25 engine and put on a delorean crankcase, so the engine went on directly. But we had to modify and custom built various other things...
The two main album are "FOTO MOTORE TURBO COMPLETO" and "PRV 2.5L V6 turbo"
cineman
Messagepar mickealkeal » Mar 12 Mai 2009 à 01:43
Comme je regrette de ne pas avoir pu venir... :(
J'espère que cette sortie se refera un jour... Merci pour les photos en tout les cas.
