News news ^^
Today, after coming back from the SC
i tried the engine with the ECU Giacomo's lended me.
Finally some better soundly engine!! All the electrical problem are solved... :wink
The problem was that i was using some low impedance injector ( the stock of the Alpine ) but the later Renix ECU i was using was for HIGH impedance injector, and gave all kind of problem running with lower one.
Giacomo's ECU, from a R25 V6 turbo, while not programmable like the first, is for low impedance injector, and when connected everything started to run right ^^
The distribution was ok, like was ok all the other things.
Now i will take a look for higher impedance injector and go on to finish the air plumbing of the turbos...
